DavidRush
Nov 29, 2025Aspirant
No Router Login
I have an old AC2000 Dual Band Wireless Access Point, WiFi Router (WAC124) which is working fine. although I am just using it as an access point. I was able to log into it a while ago but have ha...
schumaku
Dec 02, 2025Guru - Experienced User
Have an eye on the fine User Manual (For Firmware version 1.0.4.2 and greater) where you find around p.18/19
Note: If the access point/router is in router mode, you can always reach the local browser
interface by entering http://www.routerlogin.net in the address field of your browser.
If the access point/router is in access point mode, you must enter the IP address that
your existing router assigned to the access point/router. For more information, see Find
the IP address of the access point/router on page 29.
Not sure what you expect from my.netgear.com - you will find there details like serial number, registration date, ....
