Cetus's avatar
Cetus
WAX210 Management UI Rejects Password
I am a new user of a WAX210 access point.  It is ethernet connected to my switch.  It provides wifi connectivity to my devices just fine.  What it does not do is allow me access to the management UI ...
  • Cetus's avatar
    Oct 20, 2026
    Problem  solved.  Thanks to all who helped.  My problem was not the hyphen.  The password was accepted and worked when I introduced both a $ and % into it.  Either by itself along with the other stuff seemed not to be sufficient (or I changed something else, which I was oblivious to).
    The WAX210 now works perfectly in all modes.
ProSupport for Business
