mbelanger
Jun 13, 2019Follower
Built-in Cable Tester
I'm trying to better understand how the "Cable Tester" tool within the web admin works. Can one run the tests while computers and other switches are plugged into the switch inquestion? Unless you...
- Jun 18, 2019
Give it a try. Unless you plug a very short cable (below about 2 meters), it will report an open cable, and the distance to the fault is about the cable length.
It's a refection measurement - no loopback or the like - so nothing must be plugged or active to the far end. See eg. port #2 here:
schumaku
Jun 18, 2019Guru - Experienced User
