forestofdean
Dec 15, 2024Follower
cctv problem
New router sent by my ISP, an Eero 6. Only two ports in it, 1 for landline phone and 1 for fibre connection. My old router had enough ports for my CCTV data cable without the need for a separate ethe...
Dec 16, 2024Guru - Experienced User
Make sure you're wiring the fibre line directly to the eero and then the 2nd port on the eero to the switch. With devices then connected to the switch. The fibre needs to be ran to the eero directly to be managing dhcp/nat.
