KNP's avatar
KNP
Certificate of Volatility for GS105 and JGS516
Hello,   Looking for a CoV or other sanitization documentation regarding your GS105 and JGS516 unmanaged switches.   Thanks!
  • DaneA's avatar
    Dec 02, 2020
    KNP,
    Welcome to the community! :)
    Be informed that the latest GS105 and JGS516 switch model are the GS105v5 and JGS516v2 respectively (v = version).  Kindly download the Letter of Volatility on the respective links below.
    GS105v5 Letter of Volatility
    JGS516v2 Letter of Volatility
    Note: The links will expire within 2-3 days
    If you don't have any further concern, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
