KNP
Dec 01, 2020Aspirant
Certificate of Volatility for GS105 and JGS516
Hello, Looking for a CoV or other sanitization documentation regarding your GS105 and JGS516 unmanaged switches. Thanks!
- Dec 02, 2020
KNP,
Welcome to the community! :)
Be informed that the latest GS105 and JGS516 switch model are the GS105v5 and JGS516v2 respectively (v = version). Kindly download the Letter of Volatility on the respective links below.
Note: The links will expire within 2-3 days
If you don't have any further concern, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
DaneA
Dec 02, 2020NETGEAR Employee Retired
KNP,
DaneA
schumaku
Dec 02, 2020Guru - Experienced User
Disconnect powercord, and use Windex to clean ... as usual on non-managed switches. 8-)
