jrod5286's avatar
jrod5286
Follower
Apr 13, 2021
GS105 and GS108 Letter of Volatility
Can I please get a letter of volatility for the GS105NA and GS108-400AN switches?
Thanks,
Jared
  • jrod5286,
    Welcome to the community! :)
    The GS105NA is the product code for the GS105 switch in North America.  The latest GS105 switch model is GS105v5.
    About the "GS108-400AN," I believe you are referring to GS108v4 which is the latest model for the GS108 switch.
    Kindly download the Letter of Volatility on the links below:
    GS105v5 Letter of Volatility
    GS108v4 Letter of Volatility
    Be reminded that the links will expire within 2-3 days.
    If you have already downloaded the Letters of Volatility and you have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    jrod5286,
    DaneA
ProSupport for Business
