lankylad
Jun 09, 2019Aspirant
GS108 and Realtek PCIe GBE Family Controller and Windows 10
The May update of Windows 10 seems to have stopped my GS108 from working. If I connect my Realtek ethernet port on my workstation directly to the broadband router then everything is OK. If I use my o...
- Jun 12, 2019
I upgraded to the Windows 10 June Update this morning (OS Build 17763.557) and the problem has been fixed
Jun 09, 2019Guru - Experienced User
So its just the one device that is having issues? All the other devices are working correctly?
Not sure why it would only be that one device and all your other switches would work. The GS108 is an unmanaged switch so there shouldn't be anything within it (unless its bad) causing problems.
I'd try uninstalling your realtek adapter and reinstalling it. Thats where I'd be looking at for the problems.
lankylad
Its just odd that it works when connected directly to the broadband router or to another manufacturers switch.
I suspect its a Windows 10 issue, but just wondered whether anyone else was suffering the same way
- plemansJun 09, 2019Guru - Experienced User
I'm running windows 10 preview connected to a gs716tv2 without any issues. I don't have a gs108 to test with.
