lankylad's avatar
lankylad
GS108 and Realtek PCIe GBE Family Controller and Windows 10
The May update of Windows 10 seems to have stopped my GS108 from working. If I connect my Realtek ethernet port on my workstation directly to the broadband router then everything is OK. If I use my o...
  • lankylad's avatar
    Jun 12, 2019
    I upgraded to the Windows 10 June Update this morning (OS Build 17763.557) and the problem has been fixed
ProSupport for Business
