jfitch86
Apr 23, 2021Aspirant
GS108v4 8-Port Gigabit Desktop Switch no internet
Hi so I bought this switch about 6 months ago when I moved into an apartment. It has worked perfectly up until today. The day before I moved down to a new apartment. I setup everything as inst...
jonathanca14
Apr 30, 2021Guide
I assume all your wired devices are plugged into the switch and you've then one cable going from the switch to one of the LAN ports of the router? (Not a WAN port).
If thats so, I'd suggest turning off the switch and the router, turn the router back on and wait for it to load, then turn the switch back on and see if everything now works.
- jfitch86May 03, 2021AspirantI have tried reseting the modem and the switch, allowing the modem to boot fully then powering on the switch. I have even tried reseting the modem then powering the switch with only the ethernet cable from the modem plugged in and then plugging in other devices with no luck prior to making this thread
- DaneAMay 12, 2021NETGEAR Employee Retired
Welcome to the community! :)
Just to verify. Is the modem you are referring to a modem-only device or a modem-router combo?
Is the GS108v4 directly connected to the modem or it is connected to an ethernet port on a wall?
DaneA
NETGEAR Community Team
