dboothe
Nov 18, 2020Aspirant
GS116 Switch Unable to Run Ethernet and Phone Using Cat 5 Cable
Hi, I purchased a GS116 switch to expand my network which includes both Ethernet and Phone running on a single Cat5 cable. I was able to do this with my previous switch by using 4 wires (1,2,3,6) for...
schumaku
Nov 19, 2020Guru - Experienced User
Don't know the exact reason, but experienced that newer switch ports (1G and 10G switch classes) are no longer able to negotiate link rates of 100 Mb/s with just two pairs - depsite of the spec'ed fact that four strands/two pairs are perfectly sufficient for Fast Ethernet. -This is not limited to Netgear btw.
Suspect a change in the design of the Ethernet PHY by the chipset makers.
YeZ can you figure out with your hardware people what can made this change?
dboothe
Nov 20, 2020Aspirant
Thanks for the quick response.
