Nfm
Sep 20, 2023Initiate
Help needed for my GS108v2
Hello My switch GS108v2 (bought on 2007) no longer works... When powering on (no RJ45 cable connected), the ports are not tested one after the other as usual. The 100M LEDs all turn on at once for...
- Sep 21, 2023
Try instead the link under "Contact us" on my.netgear.com e.g. https://my.netgear.com/support/contact.aspx and file the form instead, for switches, select (x) "Business" and Call support should be available:
Nfm wrote:
I tried to create an RMA on my.netgear.com, but the process finished with an "somethingWentWrong'" message...
On "My Products", the status of the warranty is "LIFETIME"
Curious in which market, which country you are located. For some users, using an alternate browser does allow to work around this issue.
schumaku
Sep 21, 2023Guru - Experienced User
