klender
May 19, 2020Aspirant
how to choose which switch is best
Just moved to a home, where the previous owner left 2 switches. I have used both and both are in good working order. I would like to simplify my setup, and use only one. Is there one that is bette...
- May 20, 2020
Keep the (physically) bigger JGS one near the router or utility room (there might be a small rack or the like with the cabling), and use the smaller GS where you need more Ethernet ports than installed cables are available. Performance is the very same - these are both non-manged but full wire-sped capable devices.
The existing set-up reads to me like there are a lot of network cables installed into different areas and rooms. If this is correct, what's the point of installing a Mesh system?
schumaku
May 20, 2020Guru - Experienced User
klender
May 20, 2020Aspirant
Thanks for the answer. I need the mesh system for wireless, and futher, the wiring was mostly for the basement where he had an office with multiple jacks... generally poorly labeled.
