klender
May 19, 2020Aspirant
how to choose which switch is best
Just moved to a home, where the previous owner left 2 switches. I have used both and both are in good working order. I would like to simplify my setup, and use only one. Is there one that is bette...
- May 20, 2020
Keep the (physically) bigger JGS one near the router or utility room (there might be a small rack or the like with the cabling), and use the smaller GS where you need more Ethernet ports than installed cables are available. Performance is the very same - these are both non-manged but full wire-sped capable devices.
The existing set-up reads to me like there are a lot of network cables installed into different areas and rooms. If this is correct, what's the point of installing a Mesh system?
klender
May 20, 2020Aspirant
Thanks for the answer. I need the mesh system for wireless, and futher, the wiring was mostly for the basement where he had an office with multiple jacks... generally poorly labeled.
schumaku
May 20, 2020Guru - Experienced User
Well, I would avoid wireless backhaul on these consumer Mesh systems and use SMB WiFi APs on cables instead. That's why my customers and we here at the home/SOHO never suffer from any wireless backhaul limitations, and the wireless does run rock solid 24*366 for three decades. I'll take the challenge for checking out the wiring, and add additional cables for the upper floor instead of using anything substandard (compared to a wired Ethernet, able to run links on up to 10Gb/s). But hey, be happy, believe in marketing ...
