NNand's avatar
NNand
Follower
Oct 27, 2020
I need a letter of volatility
Hello,
I need a Leter of Volatility for the GS108.  I don't know the revision of the switch, but the S/N is 1DRxxxxxxxxx.
Thank you
  • NNand,
    Welcome to the community! :)
    I got your private message and inquired the serial number of your GS108 switch to NETGEAR Support to know the exact model of it.  Found out that its not yet registered.  The latest GS108 switch model is the GS108v4 (v = version).
    You can download the Letter of Volatility of the GS108v4 switch on this link.  The link will expire within 2-3 days.
    If you were able to download it and you have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    NNand,
    DaneA
ProSupport for Business
