kenchen_aruba
Dec 18, 2020Aspirant
JGS524 ECCN and CCATS
Hi, Can someone please provide the following information for JGS524? I need it to ship outside of the US. US ECCN CCATS HTS Code Does this Switch operate on Layer 3? If not, what layer doe...
DaneA
Dec 21, 2020NETGEAR Employee Retired
Welcome to the community! :)
US ECCN
CCATS
HTS Code
About the US ECCN, CCATS and HTS Code, kindly access and read the link below:
US Customs Compliance
Does this Switch operate on Layer 3? If not, what layer does the switch operate on?
The JGS524 is a Layer 2 switch.
Does this Switch have/use MIMO technology?
Does this Switch have/use SIMO technology?
Both MIMO (Multiple-Input Multiple-Output) and SIMO (Single Input, Multiple Output) are for wireless communications and therefore NOT supported by the JGS524 switch.
Does this Switch use in ISP/TSP?
If you need to extend your LAN, you will need the JGS524 to connect more devices hardwired like PC, network printer, etc. Be reminded that the recommended setup would be: modem-router-JGS524. You will need an ISP subscription so that you can have internet access. The JGS524 does not support TSP.
The latest JGS524 switch model is the JGS524v2 (v = version). To know more about its specifications, kindly check its data sheet here.
DaneA
NETGEAR Community Team
kenchen_aruba
Dec 21, 2020Aspirant
Hi DaneA,
Thanks for the reply.
I looked at US Customs Compliance, I see several ECCNs listed, which one do I use for JGS524?
Also, I don't see HTS or CCATS mentioned.
Thanks
Ken
