kenchen_aruba
Dec 18, 2020Aspirant
JGS524 ECCN and CCATS
Hi, Can someone please provide the following information for JGS524? I need it to ship outside of the US. US ECCN CCATS HTS Code Does this Switch operate on Layer 3? If not, what layer doe...
kenchen_aruba
Dec 21, 2020Aspirant
Hi DaneA,
Thanks for the reply.
I looked at US Customs Compliance, I see several ECCNs listed, which one do I use for JGS524?
Also, I don't see HTS or CCATS mentioned.
Thanks
Ken
schumaku
Dec 21, 2020Guru - Experienced User
Model Number - Description - Line - ECCN # - Import HTS - Export Schedule - CCATS#
JGS524 - 24 port Gigabit Ethernet Switches - Switch - 5A991 - 8517.62.0050 - 8517.62.0050 - G044731
- kenchen_arubaDec 21, 2020Aspirant
Hi Schumaku,
Thanks for the information!
Ken
- schumakuDec 21, 2020Guru - Experienced User
Glad to help - be aware I'm neither Netgear nor an import/export crack - but this should be fine so you won't be prosecuted 8-)
Hi schumaku,
It will be fine, I just need the information for our Global Trade department will let me know if the information seems to not add up.
Again, thank you for the info!
Ken
Aruba HPE
