genericuser's avatar
genericuser
Follower
Dec 10, 2021
Letters of Volatility
If possible, could I get copies of the letter of volatility for the following Netgear switch models?   GS105v5 GS305v3 JGS524v1   Thanks!
  • JeraldM's avatar
    Dec 10, 2021
    genericuser
    Welcome to the community!
    Kindly download the Letter of Volatility of the switches on this link.  Be informed that the link will expire within 2-3 days.
    If you were able to download the Letter of Volatility and you don't have any further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    JeraldM
    NETGEAR Community Team
ProSupport for Business
