dromedaris
Apr 07, 2022Follower
mode B support
According to this posting - https://community.netgear.com/t5/Plus-and-Smart-Switches-Forum/Poe-Mode-B-possible-on-pair-45-78/td-p/1928011, the following is true:
> Today's standard compliant PoE switch PSE are able to power on Mode A or Mode B depending on the ability and need of the PD. It's not a user choice, thus nothing to enable.
The datasheet of the GS108P does not mention mode B specifically. I'm interested in using a mode b only PD (two pair ethernet) with any standard (managed or unmanaged) switch that allows this.
1 Reply
- schumakuGuru - Experienced UserThe datasheet of the GS108P does neither mention mode A specifically, too.
Common agreement here is the that standards compliant PSE can negotiate Mode A and Mode B.
