PaladinKC
Aug 23, 2021Aspirant
Multi-Gig Switches and Google 2 gig fiber
This one has me at my wits end! I recently purchased a Netgear Multi-GIG XS505M to take advantage of my new 2 GIG Fiber connection. In addition, I added a 10 gig ASUS XG-C100-C card to my PC. Conn...
schumaku
Aug 24, 2021Guru - Experienced User
Client OS and driver version where this XG-C100-C adapter is installed? Grab the current drivers for the ACQ107 from https://www.marvell.com/support/downloads.html ....
- PaladinKCAug 24, 2021Aspirant
Thank you for the note. I downloaded the most recent drivers when I installed the card. I'm a little skeptic if the drivers linked ... there are no Windows 10 drivers listed ... If they haven't updated drivers since WIndows 7 and 8 ... I'm concerned! :-)
However .. I'll give them a try.
Thanks...
- schumakuAug 24, 2021Guru - Experienced User
Just select AQ107 and you get access to the 32 or 64 bit Windows drivers - and the Flash updater for the adapter (also for Windows 10 32 and 64 bit). Lots of issues with these early 10G/MultiGig cards when it comes ot reliability and performance - and the Asus drivers are hopelessly outdated....
Thanks ... I'll give it a try.
