ilcapitano77
Feb 04, 2024Aspirant
Netgear GS316 Switch - Problem with PS and Xbox Remote Play
Hi everyone, I have a FritzBox 7530 and a GS316 16 port switch. Playstation 5 and Xbox Series X are connected via LAN cable to the switch. When I use remote play on my iPad the stream freezes eve...
BrianL
Feb 04, 2024NETGEAR Moderator
Hi ilcapitano77,
We don't have any settings that we can access or change from this switch as it's an unmanaged one. What we can do is isolate the problem between the switch and your router (Fritz Box).
If in the same room, and one /or both of the gaming consoles are attached to the said switch and connected to your router via LAN (1GB) using CAT5E cable, is the issue present? Have we tried using other LAN cables or even switch ports to see if the issue is persistent?
Kind regards,
- ilcapitano77Feb 05, 2024AspirantI have not tried this yet but I will. Thank you for the advice.
Best regards
Oliver- BrianLFeb 05, 2024NETGEAR Moderator
