tharrington3
Mar 01, 2019Aspirant
ProSafe 16 port Gigabit Switch GS116v2 Unmanaged?
This ProSAFE 16 port gigabit switch (GS116v2) is unmanaged, correct? Therefore it should not have a reset button on the outside, nor should the prosafe switch utility be able to “see” the switch on t...
- Mar 01, 2019
tharrington3 wrote:
This ProSAFE 16 port gigabit switch (GS116v2) is unmanaged, correct?Yes
tharrington3 wrote:
Having ProSafe in the title confused me as my other switch (GS108T) is managed. Do managed switches always say managed on the box? The switch is working fine but I was trying to find the switch on the network with no luck. Read another post explaining that only managed switches can be accessed.The GS108T is a Smart Managed Pro switch - the GS116 isn't.
Simplified (leaving PoE and hardware versions/variants alone):
- FSnnn, GSnnn, XSnnn[M] are unmanaged.
- GSnnnE, XSnnnE[M] are Smart Managed Plus switches, with MAC; IP, et all.
- GSnnnT, XSnnnT are Smart Managed Pro switches, with MAC; IP, et all.
- Mnnnn are Manged Switch models, with one or muliplte MAC, IP, .... et all.
schumaku
Mar 01, 2019Guru - Experienced User
Yes
- tharrington3Mar 01, 2019AspirantThank you for your confirmation and insight!
