MartinCYH's avatar
MartinCYH
Wifi 6E AP router AXE11000 ECCN request
Hi Netgear,      May I clarify the ECCN of the item of Wifi 6E AP router AXE11000?  Thanks.    https://www.netgear.com/home/wifi/routers/raxe500/?cid=us-wifi6-srch-cpc&utm_source=search&utm_med...
  • schumaku's avatar
    Apr 22, 2021
    ECCN 5A992 ... as for any kind of WiFi routers.
    Be aware that US versions are fixed to FCC regulatory and typically can't be changed for operations in different legislation.
ProSupport for Business
