MartinCYH
Apr 21, 2021Aspirant
Wifi 6E AP router AXE11000 ECCN request
Hi Netgear, May I clarify the ECCN of the item of Wifi 6E AP router AXE11000? Thanks. https://www.netgear.com/home/wifi/routers/raxe500/?cid=us-wifi6-srch-cpc&utm_source=search&utm_med...
- Apr 22, 2021
ECCN 5A992 ... as for any kind of WiFi routers.
Be aware that US versions are fixed to FCC regulatory and typically can't be changed for operations in different legislation.
schumaku
Apr 22, 2021Guru - Experienced User
MartinCYH
Apr 27, 2021Aspirant
Thank you!!:smileyhappy:
schumaku wrote:ECCN 5A992 ... as for any kind of WiFi routers.
- MartinCYHApr 27, 2021Aspirant
BTW, my US colleague wants to ship the mentioned router to China.
I was told by our China broker that, this item should be cleared with China's 3C permit.
Can Netgear help to obtain the 3C permit? Or how can we fix this problem?
Thanks.
