toya
May 22, 2021Tutor
100% CPU USED(MODEL: BR500)
hi I think vpn router has a issue. though I use about 20 devices (pc,sockets,cctv,nvr,smartphone), 100% CPU Usage is too much. Before it was 20~30%(i guess). why is it happened? thx ...
DaneA
May 23, 2021NETGEAR Employee Retired
toya,
What is the current firmware version of your BR500? If ever its not yet the latest version, I suggest you to upgrade it. The latest BR500 firmware is v5.10.0.5 and you can download it here. Then observe if the same problem will occur.
DaneA
NETGEAR Community Team
