iNg6ie
Nov 07, 2022Aspirant
After two years of "escalation" the RS400 still does not find new firmware version.
If I've understood correctly, keeping the software or firmware in this case up to date, is one of the basic tenets of cyber security, the fact that "Nighthawk AC2300 Cybersecurity WiFi Router" does n...
iNg6ie
Obviously I don't know if this has been fixed in that latest version "V1.5.1.88_10.0.58", but it certainly was not fixed in second to last version "V1.5.1.86_10.0.58".
Because the WebUI does not find a new FW version, I've done all the updates manually via the same WebUI.
By "does not find" I mean:
Login -> Advanced -> Administration -> Router Update -> click the "Check" button. Description to the left of the button is:
"Check for new version from the Internet."
After a few seconds has passed, the "Firmware Version Check" has given for more than two years the same answer "No new firmware version available." and the oblicatory "Ok" button.
To insult to injury "Router Auto Firmware Update" is set to "Enable", which does not work, most likely because the router cannot find a newer firmware than what is installed.
Kitsap
Nov 07, 2022Master
iNg6ie wrote:Obviously I don't know if this has been fixed in that latest version "V1.5.1.88_10.0.58", but it certainly was not fixed in second to last version "V1.5.1.86_10.0.58".
Not an unusual situation and not limited to your model. Don't expect it to be "fixed" with the next generation of firmware.
Most experienced users disable the auto update feature and update manually through an Ethernet connection.
