magitech
Aug 11, 2021Aspirant
BR200 reservation not working
Hi, I am trying to setup the "Address Reservation" on my BR200 but it is not working. The reservation works well with my windows clients but doesn't work with my ip cams. Router assigns to each I...
DaneA
Aug 11, 2021NETGEAR Employee Retired
Welcome to the community! :)
Kindly answer the questions below:
1. Was this working fine before?
2. What is the current firmware of your BR200? If ever the firmware is not yet the latest version, I suggest you to update it. You can download the latest BR200 firmware v5.10.0.5 here. Then, check if the same problem will occur.
3. What is the exact brand/model of your IP cameras?
DaneA
NETGEAR Community Team
magitech
Aug 12, 2021Aspirant
An update, the address reservation actually works only for one windows client.
On other two clients, the reservation doesn't work.
