kc6108
Jan 26, 2019Luminary
BR500 “Instant VPN”?
How do you add a BR500 to a VPN Group inside Insight? Every time I try in the phone app I get a generic error. When I try online or via the Mac app I get an error stating a Virtual IP is needed.
- Feb 02, 2019
The virtual IP issue is fixed and deployed to production server, please let us know if you still have issue. Thank you all.
Glimberg
Jan 29, 2019Aspirant
Yes, same here. I have upgraded to firmware 5.5 and done a factory reset on both my BR500, deleted all old VPN groups, bought the premium service for VPN and I get the same message that "Unable to add device(s) because Unable to assign Virtual IP" as before.
I am not very impressed.
/ John
YeZ
Jan 30, 2019NETGEAR Expert
Sorry for the service inconvenience!
We are working on a fix to the virtual IP issue, will keep you updated.
Thank you.
- Retired_MemberJan 31, 2019I have the same issue (no virtual ip can be assigned). The diagnostic tool in the firewall info test appears warn - MQTT is blocked, use HTTP.
- YeZFeb 02, 2019NETGEAR Expert
- Retired_MemberFeb 02, 2019Now it is all ok.. Thank you very much
