tetrawest
Feb 01, 2020Apprentice
BR500 and IPSec direct VPN
On my old FVS336 firewalls, I could do a direct IPSec connection. In fact, that was the only way I could get a VPN to work from my Android devices. I am using the Insight software to get my PC to VPN...
DaneA
Feb 03, 2020NETGEAR Employee Retired
Let me share the article here on how to configure OpenVPN on BR500. Hope it helps. :)
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
tetrawest
Feb 03, 2020Apprentice
Dana,
Thanks for the respone, but it doesn't resolve the issue, which is OpenVPN picking a poor choice for the pseudo-network address.
Nor did you give any insight into why the IPSec VPN drop down doesn't give me a peer to LAN option.
James
