Retired_Member
Jan 04, 2019BR500 connection problem
Hello everyone. I bought a br500, I recorded it on insight and the light of the cloud has become blue. The problem is that I can never connect. Always compute: an error occurred while processing the r...
- Retired_MemberMay 02, 2019Hi..You can try resetting it, then register it and configure it only through the cloud .
Retired_Member
Jan 04, 2019Now it's all ok..
JelliottUK
May 02, 2019Aspirant
What did you do to fix it
I have a BR500 sat in my small office behind another router, internet works fine but any cloud services or VPN will not work. No blue light for cloud
