Neoneo
Nov 08, 2020Aspirant
BR500 NAT hairpin loopback not working
After updating to the latest firmware, BR500 NAT hairpin loopback stopped working. I see nothing in setup to enable it.
- Nov 09, 2020
Hello,
Under Use These DNS Servers you can manually enter a DNS server instead of using the one automatically assigned from your ISP.
As for NAT loopback being supported in later versions, engineering is aware that is no longer supported in later versions, however I do not have an ETA when it will be supported in later versions. For now, version 5.7.0.4 is the last release in which NAT loopback is supported.
Neoneo
Nov 09, 2020Aspirant
BR500 is somehow not on the list
https://kb.netgear.com/000049578/Which-NETGEAR-routers-support-NAT-loopback
but NAT loop back should apprarently be working with FW 5.7.0.4 from 2019.
https://kb.netgear.com/000062195/BR500-Firmware-Version-5-10-0-3
states:
"NAT loopback does not work in this release. NAT loopback is useful for accessing internal resources by public domain name.
Workarounds:
- Change device hosts file to map public domain name to local IP when working on the same subnet as a public server.
- Use a separate DNS server that can handle accessing public resources from an internal network.
- Keep using FW 5.7.0.4."
I see no entries in BR500 relavant to DNS, other than "Get Automatically from ISP" or configure manually "Use These DNS Servers", so I am unsure how to "Use a separate DNS server that can handle accessing public resources from an internal network." Could someone please advise?
Or there is a plan to fix this year old issue in FW soon?
- MrJoshWNov 09, 2020NETGEAR Employee Retired
Hello,
- NeoneoNov 09, 2020Aspirant
MrJoshW wrote:Hello,
Thanks for your reply! How "manually enter a DNS server instead of using the one automatically assigned from your ISP" can help solving the NAT loopback problem?
