dfilip
Jun 23, 2019Guide
BR500 Port Forwarding Delays & 'vpn enabled' Messages
Just noticed what appear to be two new behaviors in my BR500 ... One is that every minute in the log I see a 'vpn enabled' message: [VPN] vppnctrl: vpn enabled, Sunday, June 23, 2019 17:22:41...
- Jun 29, 2019
Just an FYI to anyone else who experiences any of this: I have disconnected my BR500 from the Insight service, rebooted the router, and the VPN messages have stopped (obviously!), the "NAT loopback" is allowing my LAN to reliably take advantage of port forwarding (sub-second connection again, before was either hanging or taking 10+ seconds to connect), and my router has stopped randomly rebooting itself. Also, I am no longer seeing the sporadic high-CPU (sporadically 30 - 60+ percent) on the BR500.
Of course I no longer have any VPN (as ports 12973 (TUN) and 12974 (TAP) hang, even when the Open VPN service is enabled, which is the only reason why I enabled Insight + Instant VPN). But having a stable, reliable, working router is much more important to me.
Another user on this forum shared that Netgear had suggested disconnecting from Insight as a possible solution to the random reboots, which is why I am sharing this, in the hope that it may help others.
No promises, your milage may vary, void where prohibited by law, etc., but for anyone who is at their wits end and frustrated with the BR500, as I was, this maybe a possible solution to regain stability if you can live without the Insight service.
DaneA
Jun 24, 2019NETGEAR Employee Retired
I found out from the NETGEAR Support Team that you already have an ongoing support ticket about your concerns with the BR500. The support expert assigned to your support ticket is waiting for the logs from your BR500 so that it can be escalated to the engineering team for further investigation. A follow-up e-mail was sent to you. Kindly respond to it.
DaneA
NETGEAR Community Team
dfilip
Jun 24, 2019Guide
That ticket is for the server rebooting itself, which it hasn't been doing lately (as far as I can tell).
I cannot provide the Insight logs requested, because I no longer have Insight. But is it relevant to provide the other logs for a problem that I haven't witnessed in almost a week?
