Retired_Member
Jan 18, 2019BR500 vpn insight
Does the vpn insight work well if the br500 is behind another router? I did the vpn but it is a bit 'too slow .. Usually what values of latency must we have? Thank you so much for any answers
JohnC_V
Jan 23, 2019NETGEAR Employee Retired
Hi Marce88,
Welcome to our community! :)
It seems that you wanted the VPN Insight to work while it is behind another router. There is no particular latency that the engineering team has provided. Have you ever tried swapping it with the other router and check if it will provide the same information?
Retired_Member
Jan 23, 2019Hi John I will try to do this test. thank you so much
- Apr 02, 2019Retired_Member
- Apr 16, 2020Retired_Member
