dfilip
Apr 03, 2019Guide
BR500 VPN w/Mac Client
I am having difficulties setting up a “Instant” VPN on my new BR500 router.
My network topology is :
[Local LAN @ 192.168.1.0/24] <==> [BR500 @ 65.110.137.192] <=> [Cable Modem] <=> ...
- Jul 17, 2019
This issue was solved by using the built-in Insight VPN of the BR500. Please reach out if you have issues using other methods.
dfilip
Apr 08, 2019Guide
Thanks for the reply. I've tried running Tunnelblick on two Mac's both running Mojave (10.14.4, one a MacBook Air, one a Mac Mini).
In both cases, I was logged into my "Admin" account, i.e., an account in the Administrators group that is the account I created when I installed my Mac, and not 'root' per se, but one which I can 'sudo' to pretty much anything.
Can you confirm whether the steps I took were appropriate, or am I missing anything? I assume that the extra files (ca.crt, client.crt, client.key) are only required if I am doing certificate authentication? But I have not done anything with those files, because I'm not quite sure how I would use them?
MrJoshW
Apr 09, 2019NETGEAR Employee Retired
Only the conf file needs to be copied to tunnelblick during the setup process. You will drag the conf tile to the top task bar and it will add the configuration. High Serria has more locked down privacy and you would need to allow the developer to be able to run the program. To do that, navigate to Settings > Security & Privacy and under "Allow apps and downloaded from" you should see the developer listed. Click allow and the program should now have access to execute the extension to run the vpn.
- dfilipApr 09, 2019Guide
The only problem is that I am running Mojave, and there is no longer an option to "Allow apps downloaded from: Anywhere". What usually happens is that if you try to run an app that is not permitted, you have (I think it is) 30 minutes to go to that same screen, where it will tell you that the app as prevented from running, with a button to "Allow to run anyway". Unfortunately, I don't see that option when I run Tunnelblick.
Another update: I was able to get the 'Downloaded: Anywhere' option to appear by running the following command: $ sudo spctl --master-disable
Apparently, the good folks at Apple have decided to hide the 'Anywhere' option, no doubt to sell more Apple Developer licenses.
Nonetheless, that did not help. I tried re-installing Tunnelblick, and that did not help.
What did help -- but not completely -- is editing the client.conf to add the remote IP of my firwall, and once I did that -- and deleted the old 'client' configuration, and add the new client configuration with the correct remote IP -- I can now connect. I must have missed the step that said I had edit this file to put my external IP in.
But alas, while I now see bytes going out, but no bytes coming back, with 'Waiting for server response' for several (>5) minutes, and no incoming bytes.
Because the client.conf had the remote IP address listed as '0.0.0.0', I have no idea what else might be wrong or missing, so I am including it in entirety here:
client
dev tap
proto udp
remote 0.0.0.0 12974
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 5
script-security 2
up dhcp-client-request.shPlease let me know if I am missing anything else. I did not copy the script (dhcp-client-request.sh) or the certificates referenced (client.crt, client.key, or ca.crt) into Tunnelblick, just this client.conf (again, after changing the remote IP to the external address of my BR500, which now allows me to connect, and I see outgoing bytes, but no incoming bytes).
I am also attaching the latest diagnostic information as a PDF.
Please let me know if you have any other suggestions,
Dave Filip
- MrJoshWApr 11, 2019NETGEAR Employee Retired
Hello,
Just to clarify, are you setting up OpenVPN with the local GUI of the BR500 or attempting to use the Insight Instant VPN? The Insight Instant VPN does not require the OpenVPN client and has it's own independent client.
