dashwell
Aug 26, 2015Aspirant
Can't Upload Invalid Self Certificate
I have a FVS336Gv3 VPN Firewall Firmware Version: 4.3.3-5 Generated a Self Certificate Request Used the CSR to purchase a CERT from Comodo. When I try to upload I get "Can't Upload Inval...
DaneA
Aug 27, 2015NETGEAR Employee Retired
Hi dashwell,
Just want to share this link below:
https://docs.google.com/file/d/0BxQ38qeNlgAycGZFbTZmMlNIOEE/edit?pli=1
Hope it helps.
DaneA
Netgear Community Team
dashwell
Aug 27, 2015Aspirant
I will review it and let you know.
Many thanks,
- dashwellAug 27, 2015Aspirant
DId not work.
Still get the same error message
"Can't Upload Invalid Self Certificate"
- DaneASep 01, 2015NETGEAR Employee Retired
Hi dashwell,
Netgear supports 2048-bit SHA1 certificate not 2048-bit RSA certificate.
It might be that the certificate you got from Comodo is a 2048-bit RSA certificate. Kindly verify it.
DaneA
- dashwellSep 01, 2015Aspirant
I had the vendor reissue the certificate as a 2048 SHA1.
Now I get a new message.
"No trusted certificate found, Can't Upload Self Certificate"
- May 04, 2020Retired_Member
