kyledwa
Dec 04, 2015Follower
Configure Multiple PPTP users on fvs336gv2
We have a fvs336gv2 with a PPTP VPN set up and a working PPTP user. When more than one computer tries to connect with this user account, both can connect to the VPN, but only the first one connected ...
- Retired_MemberFeb 12, 2016
Hi kyledwa,
Welcome to the community. All of our Prosafe firewall devices support 5 concurrent PPTP users so this should work.
From the error message you posted, and the fact the firewall has logged the incoming attempt it seems at least the the Internet address is correct as it reaches the Netgear Firewall, but can you check the username/password combo are correct, and also the correct Encryption and Authentication is set in the PPTP client to match the PPTP setup on Netgear side.
Might be worth giving this document a read over to ensure settings are matching on both ends
Retired_Member
Feb 12, 2016Hi kyledwa,
