PopWV's avatar
PopWV
Connect a SRX5308 and wirless R7000 Routers
I have a SRX5308 router which is running great. I have been asked to add a R7000 wirless router to the wired network. I am having some trouble getting them set up. The wired network IP addresses are ...
  • DaneA's avatar
    Nov 13, 2019
    PopWV,
    Welcome to the community! :)
    The wired network IP addresses are  192.168.69.1 to 192.168.69.150 the router IP is 192.168.69.1 our server is 192.168.69.2 server is the DHCP server. using 1 wan port. The wireless network needs to be set to 192.168.1.1 to 192.168.1.10. Do I need to set LAN2 on the SRX router to 192.168.1.1 and connect the Ethernet cable form the SRX LAN port to the wan port of the R7000. I tried this but it didn't work. How should it be set up.
    Not sure if this will work.  Let us try the following below:
    1. Set the R7000 to an Access Point.
    2. Create a VLAN Profile on SRX5308.  Set port 2 as the port member.  Enable the DHCP server with 192.168.1.1 and 192.168.1.10 as the starting IP address and ending IP address respectively.  Kindly read page 88-93 of the SRX5308 user manual here
    3. Connect the LAN port of the R7000 to the port 2 of the SRX5308.
    4. Check if the wireless clients connected to the SSID of the R7000 will be able to get an IP address from the VLAN Profile created on the SRX5308.
    Let us know how it goes.
    DaneA
    NETGEAR Community Team
ProSupport for Business
