dysonp
Mar 12, 2017Aspirant
Connecting to an SFTP Server
Router: SXRN 3205 I wish to connect to my SFTP server whilst on my LAN and externally. I can do this currently by accessing it via two different routes. If I am working externally, I can SFTP usi...
DaneA
Mar 13, 2017NETGEAR Employee Retired
Hi dysonp,
Kindly answer the questions below:
a. What happens if you use sftp://mydomain.com/path/to/server to access the SFTP server on the local network? If there is an error message you encounter, kindly post a screenshot of it.
b. What is the current firmware of the SRX3205?
DaneA
NETGEAR Community Team
dysonp
Mar 13, 2017Aspirant
DaneA, thanks for your reply.
In answer to your questions:
a) It connects but my concern is that it is going out to the WAN and then back into my LAN and, thereby, slowing the data connection down ie. instead of using the data transfer speed of my LAN it will be limited to my ISP connection speeds.
b) Firmware Version:3.1.1-08
- DaneAMar 30, 2017NETGEAR Employee Retired
I inquired your concern to a higher tier of NETGEAR Support and just got a feedback. It seemed that the issue is how the SFTP client decides whether to go to the internal address, or to the external address. The SRXN3205 cannot decide on that. Thus, that needs to be configured on the SFTP client.
DaneA
