dysonp
Mar 12, 2017Aspirant
Connecting to an SFTP Server
Router: SXRN 3205 I wish to connect to my SFTP server whilst on my LAN and externally. I can do this currently by accessing it via two different routes. If I am working externally, I can SFTP usi...
DaneA
Mar 13, 2017NETGEAR Employee Retired
Hi dysonp,
Kindly answer the questions below:
a. What happens if you use sftp://mydomain.com/path/to/server to access the SFTP server on the local network? If there is an error message you encounter, kindly post a screenshot of it.
b. What is the current firmware of the SRX3205?
DaneA
NETGEAR Community Team
DaneA
Mar 15, 2017NETGEAR Employee Retired
What if you try to set up port forwarding (inbound rule) on the SXRN3205. Kindly try to open port 22 and pointing to the LAN IP address of the SFTP server. To check if port 22 is really open, access this online port scanner here. Then, try to access your SFTP server either locally or outside your network via a browser using the WAN IP address (for example: http://72.63.x.x:22).
Hope it helps.
DaneA
