dysonp
Mar 12, 2017Aspirant
Connecting to an SFTP Server
Router: SXRN 3205 I wish to connect to my SFTP server whilst on my LAN and externally. I can do this currently by accessing it via two different routes. If I am working externally, I can SFTP usi...
SamirD
Mar 19, 2017Prodigy
By the very nature of dns entries, you can't have it work that way. If you have one IP for the dns entry, it will use that IP. If you have two, it will hit each one randomly.
You could have a slightly different dns for your internal lan IP, but again that is a different IP/dns.
There may be a way to do this with static routes where any outgoing connection to xxx.xxx.xxx.xxx gets redirected to your lan at yyy.yyy.yyy.yyy, but I've never tried to make such an entry.
