zerealfox
Nov 12, 2015Follower
Does the firewall/VPN series support higher signature algorithm (sha-256) than sha1?
Hello, As SHA1 is marked insecure by our security team, I'd like to know if the latest firmwares for IPSEC and SSL VPN support higher signature algorithm (ie: sha-256, sha-384, sha-512)? Regards, ...
adit
Nov 14, 2015Mentor
Which router and firmware?
Most current ProSafe routers support IPSec SHA2-256 and SHA2-512, as well as SHA-1 and MD5, neither of which I recommend using.
SSL is certificate based so there are no settings for the Authentication algorithm.
Encryption alogritms supported are DES/3DES/AES-128(not recommended) and AES-256.
