Rapsys13's avatar
Rapsys13
Follower
Dec 07, 2021
Double NAT, set to bridge mode on Netgear switch
I have a setup at my business where there are numerous switches connected to my router to give internet to all the offices there. One of the switches is the NETGEAR ProSafe™ Gigabit Dual WAN SSL VPN Firewall FVS336Gv3. This is causing double NATing which in turn is causing phone call delays and disconnects for my Nextiva phone system. I was asked by Nextiva to put the switch into bridge mode. How can this be accomplished or remedied?
Robin
1 Reply
  • schumaku's avatar
    schumaku
    Interesting question. First, you need to figure out what purpose this Dual WAN SSL VPN Firewall FVS336Gv3 device does serve for on your network - technically it's a NAT router (not just yet another switch), two WAN port, able to handle SSL VPNs for "dial-up" clients. Well possible it does also server as a DHCP server for your LAN, or a part of your LANs.
    Last but not least, these ProSAFE VPN Firewall are EoL for years - more reason to investigate what for this device is hanging around. Needless to say, disabling NAT (feasible or not is out of scope here) would kill most of the functionality.
    -Kurt
ProSupport for Business
