sogge
Jul 28, 2012Aspirant
FVG318 firmware V2.1.2-67R huge problems
Hi' everyone, Up till yesterday I had the following equipment attached to the router, and everything worked OK: Wireless: 1 PC 2 iPads 2 Cell phones Port 1-4 2 PC's 1 Satellite-receiver ...
sogge
Jul 29, 2012Aspirant
Hi' June,
By the help of a friend I found out that by resetting to factory defaults, the "Enable DSN proxy" was also enabled. Disabling this solved the problem. Thanks a lot for your reply.
Best regards
:-) Sogge
Best regards
:-) Sogge
