karolkovalik
Aug 03, 2014Novice
FVS318G: DHCP address reservation
First of all, I have a FVS318G device with the latest available firmware. As the description says, the DHCP address reservation is not working and my devices are getting different IP addresses assi...
saytar
Aug 18, 2014Aspirant
Don't quote me here......but from my understanding if you want to set a static IP for a device, you need to assign an address outside the DHCP range you assigned........if you assigned a range from 2-254 then you have none to assign to static IPs.........
I would suggest modifying your range to something like 75-150.......that leaves you 1-74 and 151-254 for static devices.
This appears to more or less default behavior for DHCP for most devices.
