psuholet
Apr 06, 2013Aspirant
FVS318G Permit RDP between all LAN computers
Well, I just got my FVS318G and have successfully configured to forward port 3389 to a specific LAN computer that I want to access via RDP from the internet. However, I want to also be able to RDP ...
jmizoguchi
Apr 06, 2013Virtuoso
psuholet wrote: Thanks for the quick replies.
RDP has been working fine between all computers prior to changing out this router...so no other issues such as you suggested seem likely.
I called support and they indicated that this router should have NO impact on local traffic, so I just tried restarting all the other switches/etc on the LAN...still no joy.
I guess I will restart all the computers as well and see if that helps.
p
Just inbound rules should not effect as long LAN subnet is same as before
Check third party frieewall in PC side make sure trusted
