psuholet
Apr 06, 2013Aspirant
FVS318G Permit RDP between all LAN computers
Well, I just got my FVS318G and have successfully configured to forward port 3389 to a specific LAN computer that I want to access via RDP from the internet. However, I want to also be able to RDP ...
Daedalus01
Apr 16, 2013Aspirant
He's actually correct. All Windows version XP and up have have RDP. He didn't specify if it was the client or server part. All versions have the Client, or can get the client.
To the OP-- If your still having issues, you can try rebooting the computers, checking to see if your AntiVirus program also has a firewall part that may need to be configured, and lastly you can turn windows firewall off and/or your antivirus program to see if it would allow connection. If you want to be able to connect to the computer using the name of the computer you can edit the HOSTS file on the computer that way when you type the name of the computer in, it will translate the name to the correct IP address.
