thepita
Aug 21, 2015Aspirant
FVS318G Wan Speed Issue
I recently installed a FVS318g with comcast being the ISP. My connection should be 75 down 25 up however I am only getting 15 up/down thru the netgear firewall. According to the documentation the FVS...
okokok
Nov 05, 2015Aspirant
I am running a similar issue only with an FVS318G-100NAS.
I get 25-27M download and 4 upload on my cable modem but when I use the FVS318G with nothing else connected except a laptop and the cable modem I see anywhere from 3-4M. I would expect to be seeing closer to 15-20M I would think. This issue has begun only recently. I have checked and used various cable but am still seeing this slow WAN throughput
SamirD
Nov 05, 2015Prodigy
That is quite strange, especially if it was working fine. Are you connected wired or wireless?
- okokokNov 06, 2015Aspirant
Wired. I wired the laptop straight int one of the ports. I also moved ports to check. Tried different cables
- SamirDNov 06, 2015Prodigy
Have you tried confirming that there isn't something wrong with your service by plugging the laptop directly into the modem?
Have they replaced the modem lately? Has anything changed on the the ISPs end? Speeds, infrastructure, pricing, etc?
I have plugged a laptop directly into the modem and I am getting 25-27Mbps. I replaced the cable modem with with a new one about 2 mos ago that is capable of higher bandwidth. This slow down has happened over the past week or so
