thepita
Aug 21, 2015Aspirant
FVS318G Wan Speed Issue
I recently installed a FVS318g with comcast being the ISP. My connection should be 75 down 25 up however I am only getting 15 up/down thru the netgear firewall. According to the documentation the FVS...
SamirD
Nov 24, 2015Prodigy
There could be a number of weird things going on. Ive seen strange things happen to routers even when just the back end of the isp was changed.
To fully diagnose the issue, it will be necesary to connect the router to another router or internet source to see if it acts strange there too.
Of course this can only confirm an issue with just the router or if there is something about the partuclar modem/router setup.
okokok
Nov 25, 2015Aspirant
So is it a hardware issue? I don't have two ISPs just one. Not sure how I can test with two ISPs
- SamirDNov 30, 2015Prodigy
To determine if it's a hardware issue, you'll need to connect it to a switch in between the fvs and your modem. If it's dropping connection to the switch (a dumb unmanaged switch), then more than likely the fvs has a hardware issue or a auto speed/duplex problem, the latter of which could be worked around by manually setting the speed/duplex.
