thepita
Aug 21, 2015Aspirant
FVS318G Wan Speed Issue
I recently installed a FVS318g with comcast being the ISP. My connection should be 75 down 25 up however I am only getting 15 up/down thru the netgear firewall. According to the documentation the FVS...
okokok
Nov 25, 2015Aspirant
So is it a hardware issue? I don't have two ISPs just one. Not sure how I can test with two ISPs
SamirD
Nov 30, 2015Prodigy
To determine if it's a hardware issue, you'll need to connect it to a switch in between the fvs and your modem. If it's dropping connection to the switch (a dumb unmanaged switch), then more than likely the fvs has a hardware issue or a auto speed/duplex problem, the latter of which could be worked around by manually setting the speed/duplex.
