thepita
Aug 21, 2015Aspirant
FVS318G Wan Speed Issue
I recently installed a FVS318g with comcast being the ISP. My connection should be 75 down 25 up however I am only getting 15 up/down thru the netgear firewall. According to the documentation the FVS...
SamirD
Dec 01, 2015Prodigy
Best I can figure is some sort of overhead, although I'd be more inclined to think it was something configured that keeps it from its full spec.
gearneterb
Dec 01, 2015Aspirant
Brian & Samir, et al.,
Brian is correct; I am "only using a FVS318G". But I would ask the same as okokok; why only 18 Mbps down when the spec is 25?
There are no other services or devices running at the time. No firewall rules, no VPN. No Internet consumers other than a single PC (running only speedtest) on the LAN side.
Under what test conditions does this product actually reach it's specified WAN-LAN throughput?
Spec says 25 Mbps down, we should be able to get 25. Not 18.
- SamirDDec 01, 2015Prodigy
I agree with you. Details of the test environment where they got the unit to hit 25 would be very helpful.
- gearneterbDec 04, 2015Aspirant
Hey BrianL:
Can you get the test conditions for us so that we can verify that our hardware meets its published performance specification?
Thanks,
Eb - gearneterbDec 10, 2015Aspirant
...crickets...
